Road Tubeless Valve...
[Closed] Road Tubeless Valves for deep wheels?
[#10388992]
I've got some new 58mm deep wheels on order and want to set them up tubeless. There's not a huge choice in valves for deeper rims (ie longest Stans seems to be 55mm and other brands on Wiggle are out of stock in the longer lengths), is there a disadvantage to getting standard valves and using valve extenders or should I just look harder to find longer valves? Any recommendations would be greatly received (although I would prefer black valves!), Thanks
Posted : 14/12/2018 1:26 pm
I bought these for my 50mm wheels on 17th September so only recently out of stock, hopefully not long before back in.
http://www.wiggle.co.uk/lifeline-universal-tubeless-presta-valve/?sku=100343130
but for now...I have used normal tubes with extenders pre-tubeless so don't see why extenders wouldn't work from a tubeless perspective
Posted : 14/12/2018 1:33 pm
Milkit do 75mm ones, they'd be spot on.
Valve extenders are the work of the devil, avoid them if you can.
Posted : 14/12/2018 1:46 pm
HED go up to 110 mm and Silca gonto 90 mm. Both have been fine in my JET6/9 combination.
Avoid valve extenders if you can. Stans are the only external threaded ones I could find. And how else will you secure the valve to the rim. I used these too. They work fine as well but the long valves were nicer.
Posted : 15/12/2018 12:30 am
Orange Seal do a long black aluminium valve
Posted : 15/12/2018 12:40 am
Ive used these on my 60/88 tubeless wheels.
http://speed-evolution.com/index.php/product-category/valves/
They’ll do a mismatch set who I got a 38 and a 60 and with the 40mm extender they are just right
Posted : 15/12/2018 1:19 am
Specialized do a long valve for their Roval CLX64 wheels
Posted : 15/12/2018 10:08 am
