Road questions
[Closed] Road questions
 Taff
[#5057059]
About to buy a new road bike so been looking at the PX RT57. Couple of things that I'm not sure on.
Firstly, will be running compact cranks (50/34)and a 11-28 cassette - I can use a mid length or short rear mech. Which one should I use? Presumably the short would be better suited.
Secondly is crank length. Been advised to run with 172.5mm. I run 175mm on the mtb but been told with compact that 172.5mm will be better. Seen similar stuff on Google but have no idea why!
Posted : 11/04/2013 3:06 pm
crank length is nothing to do with the size of chainrings so who ever said that with a compact you are better with 172.5 is talking out their hoop for a start
50/34 11-28 is a max difference of 33
a road short has a 29 max on paper.
thus the mid is the better fit. A road short will work IF you never cross gears .... on a compact you will cross
Posted : 11/04/2013 3:14 pm
 Taff
Thanks trail rat.
Posted : 11/04/2013 3:25 pm
