Road bike question
[Closed] Road bike question
 Aus
[#6022574]
Have a 38-50 chainset set up on my road bike which I find a bit heavy going. It's a square taper TA Specialities bb with an FRM chain set (all old kit). I've a Middleburn triple chainset spare so wanted to try 34-44 or similar. Problem is the front mech won't shift outwards far enough to push the chain onto the outer ring with a 107mm bb. A 103mm bb might help, or a triple mech???
Or is mixing mtb and road bike always prone to failure?!
Thanks
Posted : 09/03/2014 8:58 pm
You can mix road and MTB, and even campag and shimano, but only certain combinations work. CTC Forum might be your friend here, many tourists favour square taper BB / MTB gearing
Posted : 10/03/2014 6:58 am
Have you looked to see if you can get rings for your current setup?
Try SJS cycles or spa cycles.
Posted : 10/03/2014 8:02 am
 Aus
Thanks - my current crankset is 130BCD so unable to go lower than 38T I think.
Posted : 10/03/2014 10:19 am
What sort of shifters are you using? That's usually the limiting factor when it comes to adding an extra chainring...
Posted : 10/03/2014 10:41 am
He's not adding a 3rd chainring.
Is 2mm difference going to be enough? that' what the 107 -> 103 will get you. IIRC mtbs have different chainlines in which case this might just not work.
Posted : 10/03/2014 10:59 am
 Aus
The bike has Veloce shifters, but wanting to stick to 2 rings. And yep, 2mm doesn't seem much, it's nearly shifting so hoped it might make the difference! Wonder if a triple front mech could do the job, as chain line with the Middleburn cranks looks ok
Posted : 10/03/2014 1:17 pm
