Riser stem!
[Closed] Riser stem!
[#10843722]
I have a relatively low front end on my bike. The forks also have a relatively short steerer tube. I have fitted riser handle bars but my back could do with a higher front end. Save from ridiculous handlebars or an excessively high extension, new forks or a new bike- Are there any short (50mm or less) stems that have a high rise 10, 15 or 20mm? 35mm diameter handlebars.
Many Thanks.
Posted : 02/10/2019 8:08 pm
Hope AM 50mm has a high rise version.
Posted : 02/10/2019 8:40 pm
Thank you. Will look a bit later.
Posted : 02/10/2019 9:09 pm
There's a place in Plymouth that can replace steerer tubes, RSF Suspension. Don't know how much though
Posted : 03/10/2019 7:23 am
DMR do a short low stack stem with some rise. The low stack means you can pop another spacer under it.
Posted : 03/10/2019 11:31 am
+1 for that DMR Defy stem, has the rise and low stack that will give you flexibility
Posted : 03/10/2019 11:35 am
Thank you all.
Posted : 04/10/2019 1:58 am
