Rim width & tyr...
[Closed] Rim width & tyres
[#1547858]
I've gone from DT 5.1d's to Stans 355's, but still using the Nobby Nic 2.25" tyres, front and rear.
I've noticed the tyres seem to have a rounder profile and are wider, is this normal or am I just being daft?
Posted : 26/04/2010 8:57 pm
 mboy
It's only when you get to the extremes of tyre/rim combo's (ie. a 2.5" tyre on a Mavic 717, or a 1.5" slick on a Mavic 729) that you really need to worry.
2.25" Nobby Nic is going to be fine on pretty much any MTB rim you can buy I'd suggest. It will have a rounder profile on some, and a squarer on others...
Posted : 26/04/2010 9:09 pm
They certainly appear to have a much rounder and therefor wider profile on my Stans.
might need to drop to a 2.1 on the back 😯
Posted : 27/04/2010 7:55 am
they will be wider as their volume is the same but the width at teh bottom is smaller - the extra is taken up by the sides 'billowing' out a bit more.
I run 2.25 NN on Mavic 717's and you do have to keep the pressure up a bit to stop them rolling on the rim.
Posted : 27/04/2010 7:58 am
Had 2.25 Racing Ralphs on 5.1's, then tried them on 4.2's, more skitish in corners.
Posted : 27/04/2010 8:25 am
They'll be fine - I have a 2.35 HR on one of mine & run a pair of 2.25 NNs on Mavic 719s
Posted : 27/04/2010 8:28 am
The tyre fitting the rim is not the issue - maybe I should've explained that - it's the fact that my bike isn't overly generous on rear tyre clearance.
So 2.1" Rocket Ron it is then
Posted : 27/04/2010 6:30 pm
