Reverb speed adjust...
[Closed] Reverb speed adjuster doing very little
[#6270850]
So I thought I'd give the reverb a bleed as I was having to depress the remote lever all the way to get it to move.
Once pressed most of the way the seat post would shoot up, and if I used the speed adjuster to slow it down it would really slow things down.
A little air came out when bleeding. All good I thought.
However the seat post now flies up extremely fast regardless of the speed adjuster setting.
If I try and slow it down nothing happens.
Have I done something wrong?
Posted : 14/06/2014 11:13 pm
Had you wound the adjuster all the way to the "slow" position before bleeding it?
Posted : 14/06/2014 11:19 pm
Yes I did that. I'll repeat the cycle again and see if it fixes the problem.
Posted : 14/06/2014 11:37 pm
