Do the 380mm & 420mm both have 125mm drop? 380 would be the right length for my Pitch, but don't want shortchanged on the drop
Posted : 18/11/2012 8:46 pm
The drop is the same, the inserted seat post is different. If you don't need the extra then keep to 380mm
Posted : 18/11/2012 8:50 pm
That's what I was hoping. Cheers
Posted : 18/11/2012 8:57 pm
Can you cut the seat post if needed or is the full post sealed?
Posted : 21/11/2012 12:40 pm
Don't think I'd want to cut the post on a Reverb.
Posted : 24/11/2012 8:41 pm
is it possible to shim the seat tube to fit a reverb..... according to RS this is not possible but I cant see why not?
Posted : 24/11/2012 8:46 pm
I have shimmed mine. I run a 30.9 post in a 31.6 frame & it's fine 🙂
Posted : 24/11/2012 9:06 pm
