Reverb issues !
[Closed] Reverb issues !
[#6337048]
whilst out riding earlier my reverb just dropped for no reason, i have since blown it up to 250psi,and now it goes up own without touchin the lever.
last year it was doing similar things ,so I returned to my retailer, who inturn sent it to Fishers the Uk importer, who to be fair fixed it foc, however, i'm unsure of the warranty period, and is this a common fault or am I just unlucky ??..
Can I service it myself it its out of warranty ?.
Posted : 13/07/2014 8:28 pm
2 year warranty on Rockshox.
Posted : 13/07/2014 8:33 pm
Sounds like a seal has gone.
Full service would usually sort that one out.
They're often overlooked, but need servicing as often as your forks to get the best out of them.
Any decent LBS should be able to sort it for you.
Posted : 13/07/2014 9:01 pm
If its in warranty send it back, no point paying for a service
Posted : 13/07/2014 9:24 pm
Just remember that a warranty is the same as it is with anything else-it only stands if it's been maintained properly-doesn't mean it can be run into the ground for almost two years without a service & expect a repair/replacement FOC.
(not saying that's what's happened, just seeing it from both sides)
Posted : 14/07/2014 8:06 am
I've got a small amount of play side to side on my reverb. Is this normal?
Posted : 15/07/2014 10:21 pm
