Reverb Hose Shorten...
[Closed] Reverb Hose Shortening
[#5060296]
I've just moved my Reverb onto a new frame and the hose on it is quite a bit too long and is also a bit damaged near the threaded bit at the post end. Can I shorten the hose from that end? I've already got a bleed kit so what do I need to buy, if anything?
Oh, and has anybody got a spare one of those Reverb hose guides that I could buy, please?
Posted : 12/04/2013 2:55 pm
Can't see why you can't shorten it that end. Didn't need to bleed mine after I shortened the hose. You'll need some cable cutters though.
If by hose guide you mean a black plastic thingy that fits round the seat post you can have mine for free. Never used it
Posted : 12/04/2013 3:08 pm
I'll take you up on that offer for sure, creamegg. I would email you but you haven't got an email address in your profile.
Posted : 12/04/2013 3:20 pm
I broke mine at the seatpost end too.. you will probably need a barb replacement kit (~£7). They've redesigned it so the 'sleeve' is now metal and a lot sturdier.
Posted : 12/04/2013 3:24 pm
Will I be able to thread the barb out of the cut off hose? It's got those spanner flats and I've got a little Shimano hose holder that sits in a vice so it should be do-able, shouldn't it?
Posted : 12/04/2013 4:50 pm
Yup, should be fine.. just check the barb for damage before you reuse it - mine had snapped..
Posted : 12/04/2013 5:37 pm
Getonyourbike. YGM
Posted : 12/04/2013 5:58 pm
Thanks creamegg. It's appreciated.
Posted : 12/04/2013 6:01 pm
I've just shortened the hose and removed the damaged bit at the seat post end and bled it. It's perfect now. Thanks guys.
Posted : 12/04/2013 10:48 pm
