Replacing Seals on ...
[Closed] Replacing Seals on Rockshox Fork - Special Tool?
 tomd
[#4098380]
How important is it to use the special tool to seat the new seals? Planning on doing a service and change the seals while I'm at it. Can the new seals be carefully pushed in place or is the tool essential?
Thanks
Posted : 24/06/2012 5:48 pm
I put mine in the freezer overnight beforehand, and they went in ok. Rub them in a bit of fork oil if they're a little tight.
Posted : 24/06/2012 5:51 pm
 nbt
never used any special tools personally. IIRC I used a piece of PVC waste pipe...
Posted : 24/06/2012 5:55 pm
A socket (that fits) will be fine and fork oil both outside and inside for the stanchions
Posted : 24/06/2012 6:23 pm
just use a large socket or PVC tube - i used the plastic tube from the hover and a wooden mallet - wife wasent best pleased....
Posted : 24/06/2012 6:47 pm
Where did you get the seals from - looking at doing mine, but TfT seem v expnsive for a few small seals
Posted : 24/06/2012 9:46 pm
They're expensive for what they are, £25 for 3 small bits of rubber / foam / plastic, but if forks are serviced regularly you can get two years from a set of seals. They are a very important part TBH, it could save you money in the long term 🙂
Posted : 25/06/2012 9:16 pm
