Replacement bladder...
[Closed] Replacement bladder required
[#1858360]
Morning All
After filling my bladder this morning I discovered that it has a puncture in it. I patched this and refilled then discovered a second puncture. Both of these are on the seam and after a couple of patches on each is still leaking.
I feel its replacement time so whats good and whats not. IIRC there was one with a zip off style top for easy cleaning?
Posted : 03/08/2010 2:00 pm
If it's a Camelbak, they have a lifetime warranty on their bladders. 🙂
Posted : 03/08/2010 2:01 pm
Dakine/Hydrapak, they have a ziplock-style opening, very easy to fill and clean.
Posted : 03/08/2010 2:03 pm
Lifetime warranty sounds all good, I shall investigate and see whats occuring with Dakine & Hydrapak also.
Edit: The warranty for non Omega bladders is only 2 years so thats bubbled that one 🙁
Posted : 03/08/2010 2:24 pm
I have a Camelbak 3 litre, A Leyzene 3 litre and a Gelert 2 Litre
of the 3 I have
Camelbak is the best
Gelert is good but mouthpiece leaks a bit after you use it. (for the money, £5, it's pretty okay)
Leyzene [b](with zip opening at top)[/b] is just utter rubbish
Posted : 03/08/2010 2:42 pm
Soccer Sport discount sport chain place had some Karrimor ones for around a tenner. Looked OK.
Posted : 03/08/2010 3:43 pm
I got a Hydraback bladder when replacing one of our C.bak units a few months ago. The slide lock can be hard to undo and the valve's flow rate does not match that of the C.bak one. Clip off hose is handy but I think that the new Omega reservoirs have those now.
Posted : 03/08/2010 3:52 pm
I have a Sports Direct local to me so will have a look in there see what they have. I do like the idea of having a wider aperture for cleaning however can also see the potential downside to this.
Posted : 03/08/2010 4:07 pm
