Replacement Bearing...
[Closed] Replacement Bearings?
[#1111161]
In the process of having my 223 resprayed and the bearings joining the 2 parts of the frame are shot. Where is the best place to get replacements? The code on them is 6002RS.
Cheers,
James
Posted : 08/12/2009 11:52 am
Chain Reaction, BETD, A.N.Other shop etc
Posted : 08/12/2009 11:57 am
I use a website called Simply Bearings.
FYI, 6002 is the size, RS denotes the seal type, this bit of the code may change with different manufacturers. Avoid any with a C3 designation, these are designed for high temp applications and have different manufacturing tollerances to cope with expansion. Get a good make like SKF or FAG and even these have different ranges made out of better materials etc.
Posted : 08/12/2009 12:20 pm
Look in your local yellow pages for Bearing factors in your area , a friend of mine actually supplies the bearings for Orange .
Posted : 08/12/2009 12:21 pm
ok maybe i should explain a bit better. is there a difference in quality / a better shop to buy them from than say for example ebay.
Posted : 08/12/2009 12:23 pm
should have bought a marin- free lifetime warranty and labour on all frame bearings (which tbh was a surprise to me when i went to the shop!).
might be worth checking if orange do something similar?
Posted : 08/12/2009 12:25 pm
tthew- website looks good! any chance of a link to the one best suited on that website? Too many codes etc for me to understand.
defaultslipper- £8 quid ish for new bearings and about 20mins work isnt that much effort is it?
Posted : 08/12/2009 12:27 pm
You wont go far wrong with SKF IMO
http://simplybearings.co.uk/shop/p6214/SKF+60022RSH+Sealed+Ball+Brg+15x32x9mm/product_info.html
Posted : 08/12/2009 12:35 pm
