Replacement BB For ...
[Closed] Replacement BB For a 2016 Giant Defy Advanced?
[#7718032]
need to remove the bb to access to di2 junction box so that i can reconnect my seat post battery (wire used was fitted top down for length, so when the battery rattled loose as disappeared into the seat tube it unplugged when i fished it out, quite annoying, much longer wire will be replacing what was fitted)
its a bog standard shimano affair, might as well fit something better (is there a thing?)
is this the right BB?
http://www.chainreactioncycles.com/chris-king-press-fit-24-bottom-bracket/rp-prod110640
Posted : 19/03/2016 8:02 pm
That's a lot of money for a bottom bracket.....
Posted : 19/03/2016 9:14 pm
if it saves repeated removal and installation of a push fit part on an expensive frame then maybe its worth it?
any helpers?
Posted : 20/03/2016 10:52 am
Giant has BB86 bottom bracket which is what that Chris King fits, 24mm spindle on your Shimano cranks so yes good to go.
Posted : 20/03/2016 11:24 am
thanks
Posted : 20/03/2016 12:16 pm
