As per someone above, for short local rides I just take keys, phone, multi-tool (which has a chain tool), quick link, and water bottle in cage. Worst that's happened was a puncture (first in about six or seven years) and I had a five mile walk home pushing the bike. Could have waited at the nearest pub for the other half to pick me up but I fancied the walk and had nowhere else I needed to be.
In my case, about a 90 minute walk pushing a disabled bike, or even worse I could be forced to leave my bike and crawl down the hillside with a broken leg.
So take the phone ... but unless you have a desperate need to be somewhere an hour and half max doesn't sound like the end of the world on the off-chance you get a puncture.
I'm terrible for carrying stuff I never use BTW... but I'd be more worried that the puncture or whatever would happen on a spontanious "Oh I'll go twice the distance away" and mostly I just take the same pack or just a multi-tool (and phone)
I have a pump on frame clips. No issue at all with it. You can slip a piece of old inner tube over the head if you want. But then I do run mudguards
So take the phone … but unless you have a desperate need to be somewhere an hour and half max doesn’t sound like the end of the world on the off-chance you get a puncture.
Ok but if I don't want my phone in my pocket then I need a saddlebag, and I might as well put a tube and CO2 in it...
Just wear a cycling top, rather than a fashion top? Then you have some useful back pockets, thus removing the need for all the angst! 🙂
Ok but if I don’t want my phone in my pocket then I need a saddlebag, and I might as well put a tube and CO2 in it…
I have one of those quad lock cases.
I don't always stick it on the bars (especially if I know where I am) but the hard case is pretty good to stick in a pocket even if your not using it for navigation.
Its adsorbed dropping out onto the trail and a few crashes whilst in pockets.
Topeak do a few good bottle cage options.
I run a Topeak Ninja cage with multi-tool at the bottom, a pump strapped to the side, and a small bottle inside the cage with spare tubes, chain link, chain breaker etc, CO2 and even a light:
Only use this on my hardtail, which i only really use on shorter rides. less than 2 hrs etc:
Longer rides, i use a Evoc waist pack.
There's no angst. Just asking how people get on with just using CO2 for emergency tubes. I don't need (and didn't ask for!) advice on carrying stuff.
I don’t need (and didn’t ask for!) advice on carrying stuff.
You've been discussing and pondering the very issue, including the fashion aspect, from your second post onward....
Thought about this a lot (too much?) and I want a rear saddlebag for everything, including phone – which means it needs to be waterproof. That basically means the Topeak Drybag. I don’t like wearing roadie kit when MTBing (or at least the roadie kit I own) so there won’t be back pockets, and I really hate stuff in my shorts pockets too.
*smiley*.
The Carradice CarraDura seatpacks are waterproof, btw and far better quality than the Topeak ones we've bust or worn out .
If you don't fancy a Ziploc bag, improvise. I use an old Thomson seatpost bag. It stays under the seatpack, secured by two built in stretchy bits of material and a velcro strap to stop it shifting around.
