redesigned speciali...
[Closed] redesigned specialized tricross.
 ton
[#1325343]
last year i bought a specialized tricross.
i took it to the pyrenees to play 'king of the mountains'.
i nearley died on it because of front brake judder so bad it was like getting a piggyback on a epileptic having a fit.
i posted about it on here..........all the usual neysayers dismissed it as complacency and moaning........ 😆
spot the differance
Posted : 14/02/2010 7:43 pm
they mounted the front cable hanger from the fork?
Posted : 14/02/2010 7:44 pm
quick fix to a flawed design. ie carbon forks
Posted : 14/02/2010 7:46 pm
i got carbon forks on my JtS and have my cable hung from a under stem hanger, for the most of it i have avoided the judder - but it has had its moments, copius amounts of mud on the rim help!
Posted : 14/02/2010 7:49 pm
 ton
i took the bike back to the shop where i bought it, a big spesh dealer, withinn 2 weeks of buying it.
they dismissed it, saying the judder would stop when the brakes bedded in.
i sold the bike after my holiday to a mate, after sourcing a fork mounted brake hanger. he has never had a problem.
I have been looking for a fork mounted hanger for my bike.
Used to have lots of them and gave them away because I wasn't going to use cantis again - curses 🙂
So who has them?
Posted : 14/02/2010 8:20 pm
the new cable hanger is a PITA if you want to fit mudguards though...
Posted : 14/02/2010 8:22 pm
I have a new tricross. No brake judder at all ever. Gave up with front mudguards tho...
Posted : 14/02/2010 8:29 pm
 ton
dmiller - Member
doh
Posted : 14/02/2010 8:39 pm
dmiller - Member
Drill 2 small holes each side of the mudguard where it passes under the fork and use zipties. I do this because it stops rattles.
Posted : 14/02/2010 8:57 pm
So who has them?
You should be able to get one of [url= http://www.fisheroutdoor.co.uk//product.asp?category=140&part_no=BP1272F&find_category=140&find_description=&find_part_desc= ]these[/url] from your LBS.
Posted : 14/02/2010 9:17 pm
If anyone wants to read a pretty good article on the causes of brake judder, [url= http://velonews.competitor.com/2009/12/cyclocross/technical-qa-with-lennard-zinn-return-to-cross_101807 ]Read Here[/url]
Posted : 14/02/2010 9:21 pm
Aha, great link Chris.
Posted : 14/02/2010 9:25 pm
