I'm moving the shed onto a proper concrete base, and want to point down an anchor point or two. Can you recommend a reasonable one that represent good value?
Please note, the concrete base is already in place, so I'll need to drill and fix it in position.
Ta.
Oxford do an inexpensive one (as long as you have a 12mm bit for the anchor bolts, otherwise you have to factor that in). comes with ball bearings for blanking the allen socket.
EDIT
[img]
[/img]
http://www.oxford-shop.co.uk/item3192.htm
admittedly not exactly answering your question but the pragmasis shed shackle is worth considering.
+1 for the Hardie Secure Anchor
Having extensive experience with rock climbing bolts I would go for resin anchors (Petzl)...greater versatility.
http://www.petzl.com/us/outdoor/rock-anchors-0/batinox
#home isn't a bad anchor point...
