Recommend me a comf...
[Closed] Recommend me a comfy Road saddle please....
[#3513597]
...to replace the stock Bontrager one I have. Getting "numb" jewels and a painful aching crotch (not soreness) after 20-30 Miles.
Appreciated...
Posted : 02/01/2012 4:55 pm
 Jase
Selle SLR
Posted : 02/01/2012 4:57 pm
SLR Gel flow for long days, it's a bit subjective though. What about your shorts are they decent. Numb nuts at that distance suggest your shorts.
Posted : 02/01/2012 5:01 pm
With regard to shorts, I went from Endura's & Boils, to Castelli's & no chafing at all. Its my c*ck thats numb 😀
FWIW other than as described the Castell's feel really comfy - its more the Saddle hammering away at boney bits... :-/
Posted : 02/01/2012 5:04 pm
 Amos
I found specialised phenom really good as it moves with you it's supposedly an xc saddle but seems light enough
Posted : 02/01/2012 5:07 pm
Sell Italia SLR 135g
Have you tried tipping the nose of the saddle down 10mm
Posted : 02/01/2012 5:12 pm
 MSP
specialized romin or for an extreme solution selle smp??
Best bet is to find dealers that do loan saddles to check them out.
Posted : 02/01/2012 5:13 pm
Charge knife.
Posted : 02/01/2012 5:17 pm
Nope - how would this help the crotch-ache, just out of interest?
Posted : 02/01/2012 5:18 pm
@neilsonwheels - I'm considering a charge knife but rumours are the stitching is tough on shorts?
Posted : 02/01/2012 5:19 pm
the fisik kurve ones are actually fantastic, i had a demo on one. (however they do cost nearly £200)
the 'novel' constuction just doent let any vibration up into the saddle 🙂
Posted : 02/01/2012 5:21 pm
SDG have always been great for me but saddle choice is so subjective. Different arse shapes and all that.
I'd recommend a brooks but anyone who is already having problems with a saddle is not going to the best person to break a new brooks in. 😉
Posted : 02/01/2012 5:25 pm
I'd go for a Brooks. May take a while to 'break in' (although some are comfy out of the box) but definitely worth it in the long run.
But...
Saddles are a very personal thing, everybody above has recommended something different so try some first if you can.
Posted : 02/01/2012 5:28 pm
Relieves pressure on the Perineal nerve
 mboy
Charge saddles are abrasive on shorts, but they also give me a very numb cock! The shape suits some, but I found them to be very uncomfortable after a short time.
Mind you, not many saddles don't give me a numb cock to be fair. The only ones I've found that don't over a long ride are the SDG Bel Air (too soft and squishy for a road bike) and the Specialized Romin/Phenom series of saddles in 143mm width in my case.
Saddles are a very personal thing, but at least you can try before you buy with Specialized saddles which helps a lot!
Posted : 02/01/2012 5:46 pm
Bought a Prologo nago pas gel pretty much new off classifieds (sorry LBS). It's bloody ace. Definitely recommend one. Makes my medium sized bum very happy.
Posted : 02/01/2012 5:50 pm
Fizik Arione. have em on all mi bikes. Quite a big surface area and lightish.
Posted : 02/01/2012 5:51 pm
I'd recommend Spesh, as you can try them first. I really like the Toupe, but the Romin is less 'aggressive', or the Toupe Gel, or the Phenom.
Posted : 02/01/2012 5:54 pm
I also like the Specialized Toupe, its got a cut out too so should help the numbness issue. I use MOst Leopard and its been great so long as the angle is OK. I once did 105 miles and had a very numb cock after, adjusted the position down a bit and its been fine over that distance ever since.
Posted : 02/01/2012 5:56 pm
def make use of loan saddles to properly try out a few shapes and sizes.
if you like the shape of the charge spoon/knife than Fizik Aliante is for you - similar shape but no rough (bit of stitching rubbed a sore in one of my cheeks on lejog..) bits you can get one also with a relief channel as well now..
Aliante is a less 'flat' saddle than seems the fashion these days
either way try before you buy. You can get Specialised, Fizik and Selle Italia loan saddles.
I tried all the specialised saddles and they all feel too flat.
Posted : 02/01/2012 6:04 pm
I use a Toupe on the road with no trouble at all. I like the Phenom too. I only get any numbnes when on the turbo on another bike with an SLR XC but that'snly because I never stand out of the saddle. In normal use, I like SLRs.
Numbness can usually be aleviated by getting out of the saddle more often.
I advocate Charge Spoon's. I've never used the knife but I do wish that they would do away with the stitching detail that runs atop and along the sides. It can be an irritant.
If the upper was smooth I reckon it would be perfect.
Posted : 02/01/2012 6:17 pm
I agree - I switched my spoons to Fizik Aliante's... same is all but the same but the fizik is smooth.
Posted : 02/01/2012 6:20 pm
+1 I have an Aliante on my best roadbike, very similar shape to the Spoon. Bloody pricey though!
Posted : 02/01/2012 6:21 pm
 LeeW
Fizik Arione is easily he most comfy saddle I have, I bought one for the MTB but the pointy rear end is a pita when you're trying to get back on the saddle whilst wearing baggies. I swapped it out for a Tundra and haven't looked back.
Find out if your lbs does demo saddles, most do.
Posted : 02/01/2012 6:25 pm
they do a cheaper 'Delta' version, though only place that seems to have these is condor cycles
http://www.condorcycles.com/Sale-Accessories/10885-Fizik-Aliante-Delta/flypage.tpl.html
Posted : 02/01/2012 6:27 pm
San Marco aspide; over 1000 hilly French and swiss miles in 2 weeks away last summer without even thinking about the saddle, it was made for me! Not cheap, but worth every penny to me.
I reckon position and seat angle are more important as I have used any old hard plastic saddles off old crap bikes such as 70s Puchs with no problems
Posted : 02/01/2012 6:28 pm
gingerflash - Member
Hmmm. In the past few weeks I've raised the saddle height by an inch, and have been zone 2 training (more sitting than before).
Reckon I'll try the "tilting forward 10mm" trick next weekend first.
Posted : 02/01/2012 7:01 pm
