Recommend me a 20mm...
[Closed] Recommend me a 20mm AM wheelset
[#873727]
Apologies if this has been posted before
I want some new wheels for my 5 Spot (now 140mm front and rear).
I have some 2009 Revelations with Maxle lite (20mm thro' axle) so whats a good wheelset for all mountain/XC/trail riding use.
Ken
Posted : 16/09/2009 10:59 pm
i love my hope hoops, pro II hubs on dt 5.1 rims, seem pretty solid , have had abuse and held up well. Pretty good value for money too if you shop around.
Posted : 16/09/2009 11:01 pm
mavic en521's on pro2's
Posted : 16/09/2009 11:03 pm
Standard answer is Hope Pro IIs with either Stan's Flow rims for tubeless, or DT 5.1s (some say they dent easily), or Mavic 719/721s
This place does em cheap - not sure about the service/quality
http://www.lexs.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2elexs%2eco%2euk%2facatalog%2findex%2ehtml&WD=hoops%20hope&PN=Hope_Pro_2__Pair_%2ehtml%23a2198#a2198
Posted : 16/09/2009 11:04 pm
I run Mavic 819's on Chris King Hubs, went for the HD rear axle and Fun bolts which stiffen up the wheel face interface at the back end.
Posted : 16/09/2009 11:06 pm
Hope Pro 2's with Mavic 823 UST rims. Bomproof
Posted : 16/09/2009 11:10 pm
start with pro2s and figure how heavy you want your mavic rims to be
Posted : 16/09/2009 11:14 pm
DeeTraks have served me well.
Posted : 16/09/2009 11:16 pm
FWIW I have a 719 and an 819 with Pro IIs on my Pitch.
They survived a week of my 16 stone clumsiness in the Alps doing the Mega, with just a couple of loose spokes that needed nipping up afterwards.
Didn't pro2s used to be cheapish? For the cost of a pro 2 build these days you are getting close to some blingy factory wheelsets. Whether or not one or the other is better is another question though.
Posted : 16/09/2009 11:18 pm
Shimano XT AM here on my 5spot , have been good for me.
Posted : 16/09/2009 11:44 pm
Have experience of running the following...
CK + Mavic 819's - rims nice and strong, tubeless works first time, but too narrow to give a good profile to bigger tyres (2.2" +). Also rims are quite heavy for the width.
CK + Stans Flows - rims a nice width, and seem pretty strong, give very good profile to tyres. Requires a rim strip to run tubeless, and are quite expensive. Built up nice and light with DT Super Comp spokes.
Roval Traversees - very light but pretty strong. Require a rim strip to run tubeless. Low spoke count means not as stiff as some, but a cracking wheelset.
Mavic Crossmax SX - great wheels. The '09 versions are very stiff, light, and strong. For me, the pick of the bunch, but expensive. The '08's can be had for quite a bit cheaper, and are also good wheels, but around 1/2lb heavier, and freehub design not as srong (so I've heard).
Posted : 17/09/2009 7:35 am
xm719 rims on Hope Pro 2 hubs built by Merlin
Posted : 17/09/2009 7:40 am
