Need a 700c 32 hole tubeless disc only rim for the CX bike. Must be 20mm inner to match the front. That's a Pacenti CL25 and has been brilliant as have the SL25's from them. What needs replacing is the rear. The 2nd! Both time they have been built within the correct tension limits but the cassette side spoke holes as just starting to split. As the rim is a couple of years old and was a replacement from the distributor via Planet X I am not expecting any joy hence the need for another. Can't spend a lot. WTB or mid range DT any good? Anything else? Or even used if you have such a thing.
I've used Archetypes for years on the commuter and found them very tough. The disc-specific 'version' is called the Hydra
http://www.justridingalong.com/hydra-rim.html
Nice apart from the price.
Mavic any good nowadays?
