recommend a good st...
[Closed] recommend a good stem under £30ish please
[#6993747]
ideally looking for a 70mm stem with 5/6 degree rise that is reasonably light but will cope with a 95kg rider all for under £30ish......????
Posted : 13/04/2015 10:02 am
 Leku
Just about to post link to same one..
Posted : 13/04/2015 10:06 am
[url= http://www.chainreactioncycles.com/funn-funnduro-stem/rp-prod91491 ]These are a cracking bit of kit for the money[/url]
10mm too short, and 2 quid over budget, but hey.... this is STW 😀
Posted : 13/04/2015 10:15 am
have folks used the on ones? are the bolts made of cheese?
Binners thanks but needs to be 70mm.
Posted : 13/04/2015 10:17 am
+1 for On One, bolts are fine.
Posted : 13/04/2015 10:22 am
http://clee-cycles.co.uk/esite/P933/product
I have a 60mm Sunline V1 that's stiff as hell for £20 posted.
Posted : 13/04/2015 10:44 am
 cp
I use an on one cnc stem - they're great. Bolts are not made from cheese.
They do have a short stack height (35mm) so you may need more spacers over your existing set up.
Posted : 13/04/2015 10:59 am
thanks on one ordered and some wide flat handlebars for a tenner
Posted : 13/04/2015 11:47 am
when you get the on-one stem in your hands, check the machined edges where they contact the bars. I've had one that was a bit burred, and I've seen pictures of the results of someone else's bars been quite damaged by burrs on their on-one stem.
Definitely worth checking and a couple of minutes with some wet and dry sanding paper if it needs it.
Posted : 13/04/2015 12:03 pm
thanks ned will do
Posted : 13/04/2015 12:08 pm
Pinkbike have a code for half price on the Superstar Zenith stem this month, so works out at £13.49! Maybe not the most exciting but for the price can't grumble.
http://www.pinkbike.com/news/april-online-deals-2015.html
Posted : 13/04/2015 12:29 pm
Anyone else had any problems with headsets coming loose when using the On One CNC stem? Since fitting one to my Fatty, I've had to adjust the headset every ride as it seems to just rattle loose. Can't seem to get the stem to clamp tight enough round the steerer
Posted : 13/04/2015 12:48 pm
do I need to consider cancelling my order?
I wanted a hassle free stem as well...........
Posted : 13/04/2015 12:52 pm
 Yak
On-one stem is fine. No burrs, or loosening happening here.
Posted : 13/04/2015 12:55 pm
My headset has done the same with more than one stem.
Are you using the carbon or steel forks?
You may find it takes a few rides for the bearings to properly settle, I had to re do the stem a few times but it is fine now.
Posted : 13/04/2015 1:10 pm
3 x nope. Currently on 3 bikes (1 wife's, 2 mine)
Posted : 13/04/2015 4:51 pm
