Rear Shock springs ...
[Closed] Rear Shock springs - length
[#3717898]
How much can you mix these up? E.g. I've just bought a frame with a 5th element coil shock on it which is 2" stroke. Unfortunately the current spring is a little (very!) soft for me. Obviously the best bet is to buy a 2" travel spring, however there appears to be more room on the shock body, so can I use a spring designed for a longer shock stroke e.g. a 2.75" spring? I'm not expecting more travel as the damper stroke dictates this, just wondering if I can use a spring that a friend has laying about.
Posted : 27/02/2012 11:14 am
If it fits, yes you can, fox fit 2.25 stroke springs on 2inch stroke shocks as standard,
Posted : 27/02/2012 11:46 am
Cool, thanks, does it effect the spring rating in anyway (suspect not and that this is a stupid question!)
Posted : 27/02/2012 11:48 am
No,.. The spring rate stays the same, a 650lb x 2.25 (for example) spring will still take the same force to compress per inch as a 650 x 2
Posted : 27/02/2012 11:53 am
So long as you can still get the correct preload you should be OK.
Posted : 27/02/2012 11:58 am
I've a Progressive Ti spring in 400lbs flavour if that's of interest.
Posted : 27/02/2012 12:22 pm
Cool, thanks all.
Sorry Rickos, not heavy enough for me. I've got a 350lb and need a 500lb, otherwise a ti one would have been great.
Posted : 27/02/2012 12:25 pm
