Rear post to post 1...
[Closed] Rear post to post 180mm adaptor, where from?
[#6153541]
Can only find I.S
Posted : 29/04/2014 9:47 pm
 lump
But that's a front one, will it work for the back too?
Posted : 29/04/2014 10:01 pm
Says suitable for front disc brakes only.
Posted : 29/04/2014 10:02 pm
 jimw
The hope version (adaptor H ) for 183 says it is OK for front and rear 160mm post fitting. I would guess that means the shimano one is also suitable?
Posted : 29/04/2014 10:49 pm
mudmonster - Member
Post is post - front or back makes no difference, any +20mm Post to Post adapter will sort it.
Posted : 29/04/2014 10:56 pm
So to run a rear 180mm disc I need to get a front 200mm? or 203mm adaptor?
Posted : 29/04/2014 10:58 pm
Your frame is most likey 160mm post (runs a 160 disc without adapter)
So for a 180 disc you want a +20mm adapter (160 to 180).
I use this
http://www.chainreactioncycles.com/ie/en/shimano-xtr-mount-adaptor-front-post-180mm/rp-prod54881
Posted : 29/04/2014 11:05 pm
Ok great, thanks that's the one I'll get 🙂
Posted : 29/04/2014 11:11 pm
Had the same problem with Abigales Enduro. Fitted a same size XT front adaptor to the rear. Works a treat
Posted : 30/04/2014 8:32 pm
