rear mech not sitin...
[Closed] rear mech not siting in high gear any help not the usual problem...
[#7129593]
Hi. Got a sram x7 rear derailleur . Put on new caset and chain now rear mech won't happy sit in high gear without jump up one.
H SCREW COMPLETELY DIS ENGAGED
CABEL UNDONE
Any ideas? Thanks in advance D
Posted : 14/06/2015 10:32 am
Correct lockring used? If it's too big then the chain will jump.
Mech seizing would be the other obvious one
Posted : 14/06/2015 11:14 am
Or possibly a bent mech hanger.
Posted : 14/06/2015 11:47 am
Mech sizing?
Posted : 14/06/2015 4:44 pm
Put a washer between the mech and the frame. My Mk 1 Soul needs this to work properly.
Posted : 14/06/2015 5:53 pm
Does the new cassette need a spacer between it and the freehub? Some do and some don't even on the same wheel, although you might struggle to get the lockring on with a spacer that isn't meant to be there
Posted : 15/06/2015 5:52 am
My Hardtail frame also needs a spacer / washer between the frames mech hanger and 10 speed XT mech itself.
It just spaces it out a little so it drops into the 11t cog properly.
i think its due to the mech hanger being a bit thinner than normal in my case.
Posted : 15/06/2015 8:30 am
