Radial trueness
[Closed] Radial trueness
[#1468275]
Just built up my first wheel and i get around 1-2mm movement radially is that OK, or do i need to keep tweaking?
Built a Spank Spike up nice looking and solid but the finish could be better for the amount of money they cost.
Landy
Posted : 01/04/2010 11:23 am
I'd keep tweaking myself - I usually get it below 1mm if I can 🙂
Posted : 01/04/2010 11:35 am
How accurate is is possible to be on this? On the last pair I built, one was about 0.5-1mm out radially, the other a bit less..... Is that good/bad/OK/brilliant/sufficient/could be better/??
I have no idea, TBH
Posted : 01/04/2010 12:03 pm
True it up on Tuesday. Egg-shaped wheels for Easter, I say.
Posted : 01/04/2010 12:15 pm
Roger Musson says:
The following measurements are a guide to good trueness, as you become more proficient in wheel building you will continually try to improve on these: lateral trueness 0.2mm, radial trueness 0.5mm, dish 1mm (difficult to measure so use a visual assessment). With dish the 1mm error is distriltpted o.5mm either side which is insignificant and is far more accurate than the likely error in the bike frame and dropout alignment.
Posted : 01/04/2010 12:22 pm
"perfect wheels" may have 0.5mm, 1-2mm you won't notice.
Posted : 01/04/2010 12:23 pm
Thanks for your reply's i will try and get it a little better, its such a ball ache though tweak that, then need to check and possibly tweak the lateral. But strangely i enjoy it very satisfying seeing the wheel come good.
I need to print off Roger Musson book instead of using my laptop to read it on, might of actually read the part foxyriders quoted.
Thanks all
Landy
Posted : 01/04/2010 1:59 pm
always get the radial into line before moving on lateral true otherwise real pita to correct
Posted : 01/04/2010 2:01 pm
Imagine having to true wheels for a living
Posted : 01/04/2010 2:11 pm
Also worth remembering that you'll usually have a radial bump/dip at the rim joint that you can't really true out.
Posted : 01/04/2010 7:03 pm
How tight do the nipples have to be, do i tighten them until the spokes twist then back off the twist or until they just feel nice and tight?
Posted : 01/04/2010 7:47 pm
Nobody will point and laugh at you, 1mm is invisible from the other side of the trail 🙂 work on it till [i]you're[/i] happy with it.
Ideally the spokes should all be at roughly the same tension. If you don't have a proper tool, you'll have to judge it yourself.
Posted : 01/04/2010 8:00 pm
