Quick question abou...
[Closed] Quick question about brakes.
[#1436338]
I got shimano m575's on my bike, I bleed them due them feeling soft. Now they moan like hell when braking.
Any ideas?
Thanks
Posted : 22/03/2010 2:40 pm
Ur spoks r 2 tite
Posted : 22/03/2010 2:42 pm
You probably got some oil on the pads/rotor when you bled them.
Clean the rotor thoroughly, you could try sanding the pads, or replace.
Posted : 22/03/2010 2:44 pm
i used brake disk cleaner to try stop it to no avail
Posted : 22/03/2010 2:45 pm
do the above and stick the pads in the oven at 180c for a few minutes. should burn off any oil. never use disc brake cleaner with the pads in. It just causes oil to migrate from the calliper to the pad surface
Posted : 22/03/2010 2:54 pm
cheers for responses
Posted : 22/03/2010 4:15 pm
