Question for Banshe...
[Closed] Question for Banshee Spitfire/Rune owners.
[#6566427]
I'd like to fit a ISCG 05 Blackspire Bruiser to my Spitfire but I'm having a bit of trouble with chain rub.
Running 2x10, no rub on the big ring but when I'm on the granny the chain starts to rub on the backplate when I'm on the lowest 3 or four cogs on the cassette.
Chainset is a Sixc, it's set up as per the instructions with the washers in the correct order. I could swap a washer over from the non drive side to the drive side but I don't want to fudge the chainline.
Just hoping someone can confirm they run an ISCG 05 device on a 2x10 setup without any issues?
Posted : 20/10/2014 8:39 am
Bump for the evening shift.
Posted : 20/10/2014 8:33 pm
 kane
My rune is a 73mm BB so there shouldn't be any spacers on the non-drive side. Not sure if the spitfire is the same.
Posted : 20/10/2014 9:00 pm
Bugger, looks like it my not work then 🙁
Spacers are correct on the bb, there are some on the sixc crank that can be moved from one side to the other. Might have a play with those to see if I can get a bit more clearance but I don't want to upset the chainline.
Cheers.
Posted : 23/10/2014 10:36 pm
