Pushing barb into X...
[Closed] Pushing barb into XT brake hose
[#6270713]
I was struggling to push the barb into an XT brake hose after shortening it. Fix was to gently heat it up with a hot air gun, it then slipped in as easy as anything, but became fixed solid when it cooled down.
(Disclaimer: I haven't ridden it yet, so perhaps it will explode, who knows).
That is all.
EDIT: another hot tip is to have a small black and white dog with a long swishy tail around to help you by finding the olive when it drops off onto the floor.
Posted : 14/06/2014 9:39 pm
Or use the yellow blocks supplied to clamp it in a vice and tap it in with a soft mallet...
Posted : 14/06/2014 9:43 pm
+1. Pretty easy really doing it this way.
Posted : 14/06/2014 9:44 pm
You don't even need a vice. The square cut out on Park cable cutters grips the blocks perfectly.
Posted : 14/06/2014 9:51 pm
Get a Jagwire Pin Driver.
Makes the job a pleasure.
Posted : 14/06/2014 10:01 pm
+1 for Jagwire pin driver
Posted : 15/06/2014 12:00 am
Honestly, all you need is a hammer. I can appreciate your obsessions with fancy tools though. 🙂
Posted : 15/06/2014 12:54 am
svalgis - Member
Honestly, [b]all you need is a hammer[/b]. I can appreciate your obsessions with fancy tools though.
yup.. the old tried and tested method of brute force and ignorance works for me everytime
Posted : 15/06/2014 1:31 am
Just use the supplied yellow blocks and a hammer
Posted : 15/06/2014 2:09 pm
Which method do you prefer for installing the barb? How is the result significantly better than the one which Shimano themselves recommend? Sorry for my ignorance. 🙂
Posted : 15/06/2014 2:18 pm
