PUSH Turner bushing...
[Closed] PUSH Turner bushings?
[#5664632]
I need some new bushings for my 5 Spot and unless i buy a full replacement kit from Silverfish at over a hundred quid the only other option i have got is the low friction bushings that PUSH provide.
Has anyone used them? if so how did u find them. I have had the rear shock PUSHed by TF Tuned and the bike feels exactly how i like it so i really dont want any more small bump sensitivity in the rear TBH.
Posted : 05/11/2013 12:23 pm
I fitted them to my pushed flux which also had the needle shock bearings. I also thought about having too much sensitivity but that wasn't the case - I think it just worked even better.
That was a medium flux, I then bought a large flux which has normal bushings and shock bushings and a non-pushed rp23, and I am now more aware of the suspension, whereas before I wasn't.
I am going to get this shock pushed (or swap it over) and fit some more needle bearings and push bushings.
Posted : 05/11/2013 12:31 pm
Cheers Turnerguy, just pushed the button on these. Ill give them a bash and see how i get on.
Thanks 🙂
Posted : 05/11/2013 12:39 pm
Mactheknife if you get them can you give me your opinions as I'm in the process of rebuilding my 5 spot after comes back from powder coating and was thinking of getting these!
Posted : 05/11/2013 12:40 pm
No worries Renton, it may be a few weeks before i fit them though.
Also when u stripped down your 5 spot how did you remove the black DW link at the bottom of the frame without causing damage? After removing the 2 screws and plate on the drive side i had to use a soft mallet but i didnt like doing it that way. Mine was very tight.
Posted : 05/11/2013 12:47 pm
Yep same way as you!!
My bottom pivot bolts are stuck onto one side of my dw link so need to get them off some how???
Posted : 05/11/2013 12:54 pm
Did you manage to find a powdercoaters near you then? i was gonna do that but have lost all interest TBH.
I found stripping down the 5 spot was very very easy apart from the DW Rocker. Get some good loctite and a torque wrench for reassembly and all will be good 🙂
Posted : 05/11/2013 12:58 pm
I've sent it off to fastline coatings in Preston. Vortex racing on here had his done there and they did a very good job!!
Plenty of torque wrenches and loctite on hand ready for the build!
Posted : 05/11/2013 2:07 pm
Fitted a set to my HL 5 Spot last month. Fitted with a Pushed RP23.
Made a noticeable difference to the small bump performance of the bike. Seems to be the cheapest way to replace them too, if all the bolts, axles etc are ok.
Posted : 05/11/2013 6:39 pm
Glad to hear people rate them. I've got a set waiting to go on my 6 pack.
Posted : 05/11/2013 6:40 pm
