The world famous eTrex H can be had for £60 including postage!
anyone managed to get one hooked up to their PC, I'm still at a complete loss with my plain old legend one and TBH without the ability to up/down load routes its useless, i can read a map well enough not to get lost, I just want soemthing that means I don't have to bother!
Spooner - what is the problem? Did you try gps babel? Another one worth a look is gps utility.
I assume you have a USB converter, or have the serial ports mapped properly in windoze?
I would get one of these if i had not just spunked £170 on a Forerunner 405....but then it is only £60....arghhh!
Are these easy for the IT-challenged to use?
Yes unless your a spoon.
I had loads of trouble setting up a cheap serial>USB converter off Ebay, but if this one is USB it will be easy.
The eTrex H needs the USB to serial converter, but this cable works out of the box.
[url= http://gpsbitz.co.uk/shop/index.php?act=viewProd&productId=22 ]http://gpsbitz.co.uk/shop/index.php?act=viewProd&productId=22[/url]
Unless of course you already have a suitable serial port on your PC
Does the Etrex give distance travelled? Online manual doesn't mention it
Yes
will this work to convert serial to usb?
[url=http://]clicky[/url]
