Probably a dumb bra...
[Closed] Probably a dumb brake mount question
[#2944683]
Does an avid elixir caliper go straight onto a fox van 36 fork without an adaptor for 160mm discs? (IE PM -PM) My elixirs have turned up and they have an is to pm adaptor, but my fox forks are PM.
Posted : 14/07/2011 12:49 pm
the calipers will be PM as they have an adaptor that turns a PM braek into an IS brake Shirley?
Posted : 14/07/2011 12:52 pm
yeah they are pm, so I was just checking that standard pm is 160mm therefore no adaptor needed..(I think I know the answer already but as I'm at work I could order the adaptor know if needed, although I cant find one so it mustn't be needed)
Posted : 14/07/2011 1:32 pm
Juicy 5's go straight on PM fork at 160mm, so I expect your Elixirs are the same... Presumably they came with 160 rotors?
Posted : 14/07/2011 1:39 pm
yup 160 rotors. Thanks, I was convinced, and then had a crisis of confidence.
Posted : 14/07/2011 1:41 pm
