Pro 2 freehub beari...
[Closed] Pro 2 freehub bearing replacement - grrr!
[#5453779]
I've replaced the freehub bearings in my pro 2, put it back together and it binds/drags. Took it apart, noticed that the outer of the pair of small bearings isn't flush, but no amount of tw*tting it with a hammer/drift will get it flush. Should it be? All the seals & spacers are in place and seated properly so it can only be the slightly proud bearing that's making it bind. Top tips anyone?
Posted : 24/08/2013 10:09 pm
Mixed up spacers?
Posted : 24/08/2013 10:30 pm
Have you remembered the little washer that sits between the freehub and hub shell? (iirc)
Posted : 24/08/2013 10:31 pm
Checked and double checked 🙂
Posted : 24/08/2013 10:37 pm
Also that it's important that the washer between the two freehub bearings is free to move, and not static and contacting the two bearings? (unless you've already checked that 🙂 )
Posted : 25/08/2013 12:48 am
Don't hit it with a hammer?
Everything in the right order? Heat (bucket of boiling water) should expand the freehub body enough to move the bearings round.
Posted : 25/08/2013 12:57 am
Pics ?
Posted : 25/08/2013 8:25 am
Those bearings definitely shouldn't sit proud, we normally press them in using a vice (preferably with the correct sized presses).
Posted : 25/08/2013 8:27 am
