Possible carbon ste...
[Closed] Possible carbon steerer trimming cockuppery...
[#8026179]
Don't ask how, but I didn't realise the steerer on my roadie forks was carbon until I started to cut it down. I'd measured the cut so that the stem will sit on the top of a couple of spacers, with the stem cap directly on top that.
Now, I measured the steerer so it would be a few mm below the top of the stem clamp, which, on a steel steerer, would be perfect. However, am I right in thinking that a carbon steerer needs to go all the way through the stem clamp, with a spacer on top?
If so, I've cut it too short 🙁
Posted : 30/08/2016 7:55 pm
 m0rk
Yup, I was always taught to leave a spacer on top. Can't remember why now, but I still do it.
Can you get a lower stacking headset or shorter stack stem?
Posted : 30/08/2016 7:58 pm
Flip the stem (if it's a neg rise), or get one with some rise?
Different manufacturers say different things. It wouldn't bother me to run it like that.
Posted : 30/08/2016 8:00 pm
this can be fixed if you really are concerned, Bond a steerer plug in that's the cure all cervelo do one and will stop your steerer splitting and ruining your face
Posted : 30/08/2016 8:07 pm
Also make sure that you use a torque wrench to tighten the stem - there is a greater risk of crushing and collapsing the steerer when it is flush (part of the reason for the Cervelo problems)
Posted : 30/08/2016 8:21 pm
Cheers chaps.
Posted : 30/08/2016 9:28 pm
