I need a headset with plus 5mm lower cup to help keep the geometry the same when fitting a slightly shorter fork than the frame was designed for. I've seen the Cane Creek S3, but wondered if there are there any other options?
Thanks,
Ian
On-one smoothie+5?
FSA do a +5 version of the Orbit MX IIRC. Although I would recommend the CC S3 too. I've had the regular version for a couple of years now, no problems (same for a regular Orbit MX).
losing/gaining 5mm will make sod all difference to the head angle, if the change in handlebar height bothers you, use an extra spacer under the stem.
wwaswas & warpcow - thanks. On-one is cheaper, so might go for that.
ahwiles - bar height isn't the concern. Just trying to preserve a similar head angle when going from 475mm fork to a 460mm. Will probably try without first anyway, but assessing options in advance.
Ian
I had a +5mm (I think) race for a Chris King headset. It was not manufactured by them, rather some frame manufacturer who had clearance problems (maybe ventana).
edit: actually they make one themself:
http://chrisking.com/parts/baseplates
ok, so you're losing 15mm...
use a +5 headset and a bigger tyre?
easy.
Thanks kamina - that looks perfect. Means I haven't got to swap headsets if I want to swap forks back 😀
ahwiles - yes, that's the plan - hence the original question 😉
