Please help me....
[Closed] Please help me....
[#485122]
maybe an obvious question so im sorry.... 😐 How do i remove the star nut(?) thingy inside the steerer tube? the thread sheered and it needs a new star nut fitted.
Posted : 19/04/2009 10:30 pm
Just bang it a bit further down the steerer and then fit a new one.
Posted : 19/04/2009 10:32 pm
i have no idea im sure the whole point is that they go in and stay in so why not just bash it down inside the steerer instead?
Posted : 19/04/2009 10:33 pm
just knock it down a bit & put the new one above it
(or knock it right through if your steerer has a constant bore)
(or hacksaw off a couple of the legs of the star & it might drop or pull out)
(and don't tighten it so hard next time - you're only tensioning the bearings with it)
Posted : 19/04/2009 10:34 pm
Knock it out the bottom with a hammer and a drift of some sort
Bang it further down or all the way through if you can.
Posted : 19/04/2009 10:38 pm
Like this
[url= http://forums.mtbr.com/showthread.php?p=1189999 ]Star nut removal[/url]
Posted : 19/04/2009 10:45 pm
cheers guys.
scaredypants - i make sure as to not over-tighten these. it looked like some sort of metal fatigue. was a bit worried, but ive checked the whole fork over and it seems ok.
Posted : 19/04/2009 10:56 pm
no offence intended finners 😳 - just wasn't sure you'd be aware
(is it possible the stem was a bit loose & stressing the bolt somehow ?? must admit, seems unlikely to me)
Posted : 19/04/2009 11:23 pm
