Play on a XO GXP cr...
[Closed] Play on a XO GXP crank - any suggestions?
[#4503844]
I have a 73mm GXP BB in a 73mm BB shell with an XO crank. The crank is done up good and tight but there is slight lateral play if I pull on the the end of the crank. Any suggestions?
I was thinking of trying a spacer but given both BB and shell are 73mm there shouldn't be a need, right? I don't feel I should tighten the crank more.
Any help greatly appreciated.
Rich
Posted : 28/10/2012 6:45 pm
New bb, gxp are easy to fit and fairly cheap.
Posted : 28/10/2012 6:53 pm
Thanks for suggestion but crank and bb are nearly new so replacement shouldn't be necessary.
Posted : 28/10/2012 6:56 pm
Take it off and re grease the bearing and around the crank, then re fit to the required torque, use a torq wrench. You will find the load on the SRAM site.
Posted : 28/10/2012 6:59 pm
You probably won't get the crank bolt up to the correct torque with a conventional allen key. It's something daft like 40Nm IIRC.
Posted : 28/10/2012 7:03 pm
There should be a spring washer fitted,if this is there you can get small packers(spacers) that fill up the spaces and adjust the chain line
Posted : 28/10/2012 7:06 pm
What does the spring washer look like? One didn't come with the crank.
Posted : 28/10/2012 7:16 pm
It takes a lot more force than I thought to do up my X0 cranks- I'm using a Hope BB with GXP adapter.
Posted : 28/10/2012 7:18 pm
I thought it was something like 54Nm, but the point still stands, it's quite a bit if you don't have a decent lever.
I can't see how the spacer will remove play from the bearings.
Posted : 28/10/2012 7:28 pm
50nm I think for X0 cranks.
Truvativ BBs are pish though so even though there's plenty of other likely causes, I'd be checking that first.
Posted : 28/10/2012 7:29 pm
I'm sure you know, but GXP cranks only load on the NDS bearing cup, and the other crank "floats" . This is why you need it so tight to eliminate any play, as opposed to the Shimano principle.
Posted : 28/10/2012 7:31 pm
I have a long handle Allen key so I should be able to give it some wellie although I already thought it was pretty tight. Thanks for advice.
Posted : 28/10/2012 7:48 pm
As you tighten, keep an eye on the NDS bearing, and watch the crank "close in" on it. Mine takes a lot of force whilst there is still a visible gap. Once the gap closes, you can then cinch it nice and tight.
Posted : 28/10/2012 7:59 pm
i knocked a gxp bearing out in less than a month they a pile of shi*e
Posted : 28/10/2012 8:36 pm
I have mine in a Chris King BB so might be different
Posted : 28/10/2012 9:01 pm
