Play in Forks
[Closed] Play in Forks
[#2298757]
Evening All,
Stripped, cleaned and did a lower leg service on my revelations this afternoon. All went well and it's dead easy to do but what I did find was an amount of play when rocking the bike back & forward with the front brake on.
I checked the headset, brake calliper, brake mount and they are all good, but there was still about 2mm movement. Could it just be the flex from the rotor or is it more sinister and is going to require new lower bushings, is it a DIY job and who sells them??
Posted : 19/12/2010 9:56 pm
 nuke
As I was once told by TFT, stick your finger between the stanchion and lower leg arch, now apply the brake and rock the bike...if it pinches your fingers, it's the bushings. Bushings are not a DIY job imo.
Posted : 19/12/2010 9:59 pm
Nips to garage and checks.
No pinching going on
Posted : 19/12/2010 10:11 pm
 nuke
Ok, next, are they U-Turn? There will exist a certain amount of play in the U-Turn helix.
Posted : 19/12/2010 11:13 pm
Cheers Nuke, Thinking about it today now the alcohol has worn off, some details of the forks might help.
2010 Revelations, Dual Air, U-Turns, 150mm with Black Box.
They were recently treated to new complete Upper's due to wear on the lower stantions and the air unit as it had blow a seal, so I'm thinking it's just a normal thing as surley they'd have informed me of any bushing wear (and charged accordingly).
I'll keep an eye on it and see if it gets any worse. I did check the lower legs when I stripped them and there was no sign of any rubbing/marking.
Posted : 20/12/2010 12:22 pm
Did you get new seals for the lowers when you changed the uppers?
Posted : 20/12/2010 12:27 pm
I'm assuming so as it was all done by Fisher
Posted : 20/12/2010 12:32 pm
carlos,
Try compressing the forks, and then hold brake on and then try and rock it, does it still have play? Was told to do this for my '10 revs (non-uturn though)by TFTuned, if you still have play, is the play coming from the headset, tightened enough etc?
Posted : 20/12/2010 12:36 pm
brake pad moving in caliper?
Posted : 20/12/2010 12:46 pm
DM - Ok, I'll try that tonight.
I checked the Headset, Rotor, Caliper, Maxel, Hub Bearings and all is tight.
Posted : 20/12/2010 12:47 pm
Are you turning the forks through 90 degrees to rule out headset/brake/axel movement? Worth a try.
Posted : 20/12/2010 2:02 pm
I had something a similar.
In the end I found that the star fangled washer thing was moving
even when nipped up.
New washer with a spacer to lift it out of the groove made by the old washer worked.
Posted : 20/12/2010 2:28 pm
Van Halen - Member
This is very common and often missed as it's not easy to see. Hold the front brake on and rock the bike back/forward and see if the rotor moves in relation to the caliper - if so, that's it.
Posted : 20/12/2010 2:36 pm
