As part of my university course i have been assigned the group project of coming up with a solution to pinch punctures.
I would appreciate if you have a spare few minutes to fill out the following survey to help our cause.
http://www.surveymonkey.com/s/QPSDYB6
Thanks in advance
Filled it in for you but in short I found the best solution to pinch flats was to go tubeless.
Did it. Can i have my prize now?
My solution is to run higher pressures.
i ticked tubeless then got a bit lost at Q7
Filled in. I think you need to make a bigger distinction between road and MTB.
I run tubeless on both my MTBs and never pinch flat but on the road bike i do get maybe one a year but high tyre pressures and pie avoidance keep these to a minimum.
Done. Good luck with the research.
Done the survey.
PS. Have a look at my idea here:
http://singletrackworld.com/forum/topic/stupid-idea-tubeless-related
Spaff?
When I was at university we did things like cosmic microwave background radiation and the critical percolation probability for a 2D infinite lattice. What's the world coming to?
