Pedal pin height ad...
Pedal pin height adjustment - reduced diameter washers
[#12821759]
Where can I get M4 washers with a 7mm outer diameter? All I can find is 8mm ones.
They need to fit into 7.5mm diameter recesses in the pedal body, so need to be the same diameter as the hex cap head of the bolt.
Shorter pins go in 2mm increments which is too much. And ideally I don't want to get into grinding down bolts or drilling out M3.5 washers.
Posted : 14/05/2023 6:04 pm
Just file the pin down a bit?
Posted : 14/05/2023 6:43 pm
