Oxford Brute Ground...
[Closed] Oxford Brute Ground Anchor
[#6995592]
I'm thinking of fitting a ground anchor in the garage. However we are likely to be moving within the year. So,does anyone know if you can remove one of these (rental property so I can't just leave it)? I was thinking angle grinding the unit/bolt heads. At £20 destroying the ground anchor isn't a problem. Hopefully somebody has tried this?
Posted : 13/04/2015 11:33 am
Can't see that being an easy job TBH. The only ground anchor I can definitely see that is removable is [url= http://securityforbikes.com/ ]Double Doofer[/url]... yes a huge amount more expensive but will fit the larges chains (an issue for many ground anchors) and is removable.. so you can just keep reusing (if you move).
I like the look of the Hardie ground Anchor range but can't see if the bolt head is protected by purely the arch/chain, or if it's a one off installation
Posted : 19/04/2015 11:22 am
Hi.
So I use these and am in your predicament now.
I'm leaving rental property to newly bought house.
I always knew there would be no chance it would come off (except leaving an ugly botched hole in the concrete floor).
So i will be leaving it in shed. If they say anything I'm going to say I think it adds value to their shed. Which I genuinely do...
Posted : 19/04/2015 12:08 pm
And if they really don't want it left in I'll get the SDS drill out, remove it and fill in the holes...
Posted : 19/04/2015 12:15 pm
