Orange stage 4 cran...
[Closed] Orange stage 4 crank length advice
[#9906295]
so I’ve just pulled the trigger on xl stage 4 and I’m in the process of putting the build together, I’ve got access to some 2nd hand xt cranks off a friend which are 175mm long, does anyone who currently rides a stage four have any advice on whether these will work out ok or best to source some 170’s? Had 175 on my patrol c and it was shite. Cheers
Posted : 22/03/2018 6:15 pm
Yeah I’m not suggesting I could tell or it would be any benefit or disadvantage on a road or fire road but with some low B.B. bikes that run a fair amount of sag it can make a difference whilst tackling technical climbs. My patrol would **** on everything if I rode flats but was ok ish if I ran clips.
Posted : 22/03/2018 7:47 pm
175's on my segment if that's any help.
Posted : 22/03/2018 8:13 pm
 StuE
170 cranks on my large segment, gives a little bit of extra clearance in ruts and such
Posted : 22/03/2018 9:29 pm
I went from 170 to 175 on my segment and it was ok, but caught the pedals occassionaly
Posted : 22/03/2018 9:53 pm
No direct experience of the stage 4 but on paper the bb is even lower than on my smuggler. I had to switch from 175s to 170s on that as the pedal strikes were driving me nuts.
Posted : 22/03/2018 10:18 pm
Yes and that was my concern, only caveat being the transition bikes are designed to work best when running 35% sag where as the orange will be closer to 25% so fingers crossed it shouldn’t be a huge issue.
Posted : 22/03/2018 10:32 pm
