How do I get the damn thing off - its not just a case of removing the 4 bolts?
Posted : 04/02/2013 1:09 pm
Pull harder or hammer? It is from Yorkshire
Posted : 04/02/2013 1:11 pm
Remove 2 bolts and push the pins out.
Posted : 04/02/2013 1:12 pm
If it's the same as my missus's. There should to be two bolts at each end of the shock that screw into a threaded tube. Remove one bolt from each end of the shock, then pull the other bolt and threaded tube out and the shock will drop out.
Posted : 04/02/2013 1:15 pm
Done. Thanks for the quick replies.
Posted : 04/02/2013 1:25 pm
