Orange 5 cable rout...
[Closed] Orange 5 cable routing
[#3805734]
my 3week old orange 5 has started rubbing through the rubber grommet in the swinger! ,its the one on the front mech thats the issue,just wondered if anyone else had had a similar problem.
Ill sort it like but should i need on a bike only 3 weeks old & been out 4 times! .
Posted : 24/03/2012 9:53 pm
 Del
front mech?
if it is a cable going into the swinger just put a drop of lube on the outer.
Posted : 24/03/2012 11:45 pm
Had mine since 2008, was still on it's original until last year when they fitted a new one after it was re-sprayed. No issues with any of my mates bikes, nor any that we've sold.
Posted : 25/03/2012 8:19 am
Mine is a2009 and no issues with that mate.
Posted : 25/03/2012 8:23 am
The cable of the front mech,has has all but rubbed thru the grommet already! ,a bit too soon i thought, but im gunna slleve with piece of pipe.
Thx anyway guys.
Posted : 25/03/2012 9:15 am
Are you sure you mean grommet?
The cable for the front mech goes from the shifter through a couple of cable mounts on the top tube and drops down on the seat tube.
The only grommets on mine are on the swinging arm for the rear mech cable and rear brake hose and I have not had any problems.
I did have to destroy a grommet when I fitted a new brake hose though!
Posted : 25/03/2012 9:24 am
yes what grommet for front meh there for rear brake and rear mech
mine fne after 4 years
Posted : 25/03/2012 9:28 am
Just looked now its the rear mech not the front one,but its nearly rubbed through!
Posted : 25/03/2012 9:37 am
My bike is part built (new frame) and the pressure has split one by just sitting. Anyone got an eBay link for some grommets? I'm way too tight to pay £6.50 posted.
Posted : 25/03/2012 9:47 am
Any good car accessory should have them,im goin to use a bit of car washer pipe,sliced down its length slide it down the cable inside the grommet,so hopefully itll stop the chafing,.
Posted : 25/03/2012 2:01 pm
