On-one/Avid juicy h...
[Closed] On-one/Avid juicy help?
 taka
[#722101]
just got one of my On-One frames today and i have avid juicy 5 brakes the only problem is i want to route the cable through the correct routings provided. the problem with this is that i have never personelly bled my own brakes i havent go a brake kit i have watched someone do it in a bike shop on work exsperience but cant remember much? i dont realy want to end up takeing it to a bikeshop as i will be charged stupid prices for a fairley simple job "i hope" has anyone got any tips? and has anyone got an Avid juicy 5 bleedkit i can borrow?
cheers tom
Posted : 20/07/2009 6:37 pm
Google Avid brake bleed. There's a few helpful 'How to do it' videos on Youtube.
Posted : 20/07/2009 6:40 pm
I was in exactly the same position with my Juicy 7 and new inbred frame. I took the plunge and bought a bleed kit and it was all much easier than I thought it was going to be. There are a couple of instructional videos on YouTube that really helped. Just take it step by step and you'll be fine!
 nuke
iirc its not just a case of removing the hose from the lever and threading through. The hose needs to be cut and then a new hosebarb and olive need to be used (it is maybe possible to re-use the hosebard and olive but not really worth it for a couple of quid and they do come with the bleed kit iirc). Then, when its all back together, you need to bleed it. All a bit of a PITA.
I've done it a couple of times in the process of building up my O-Os; tbh, if I was building up a frame again, I'd just ziptie the hose instead.
Posted : 20/07/2009 6:51 pm
 taka
might be an idea to ask the lbs how much it would cost for them to do that then?
dont want to **** it up making the costs even more
Posted : 20/07/2009 10:18 pm
Tom
buy the kit - its dead easy if you watch the youtube vid
Posted : 21/07/2009 11:55 am
You could try what I did on my old DN6 inbred.
Hacksaw through the cable guide, bend it back, pop in the hose, bend back to correct position. Smooth it out with a bit of araldite and jobs a good un. Twice as much effort and hassle as bleeding your brake and you've now got a slightly shagged frame.
Posted : 21/07/2009 12:00 pm
lol @hugo
Posted : 21/07/2009 1:13 pm
