I wonder if the top cap is being deformed when its nipped and pulling down and touching the steerer tube. I normally measure the clearance and try to leave 2 to 3mm plus. Maybe with this type of headset/cap I need a bit more. I will play around with the spacers and report back.
Thanks for all your suggestions and help!
Try it with a larger spacer above the stem (giving more steerer clearance) and see if the problem persists.
Are you 100% sure the races are in the right way up/correct for top and bottom? With cartridges you probably can't do it wrong but I contrived to fit one race the wrong way round on a WTB greaseguard headset and had exactly the same symptoms as you describe.
im going with headset, if you use spacers under the stem make sure they are pushing the ( sorry for the grammer i did see the diagram but didnt pay attention), wedge shaped, usually plastic part.
i had the same problem in the end the spacers were pushing the top bearing cover not the wedge and therefore blah blah stem comes loose bong.
Will try it with 4 to 5mm like Stoner suggests and try it tomorrow night, see if I have any joy! There is no top cover on this type of headset, the spacers sit on the compression washer. The bottom race on The PIG is huge so can't mix up. It's meant for bmx and downhill so its quite strong. 😕
put a threaded 6mm bar through as a headloc.
never loose again.
I have 2 456 stems fitted to 2...456's!!
Both with FSA headsets and neither has ever shown the slightest inclination to budge. The steel 456 has been built up since 2005 and had almost no maintenance done at all.
Having said that I can't think of a single stem that has worked loose on any of the 10 bikes I have 😳
I am slightly well built & tighten bolts for a living so that might have some bearing on the matter 😉
