old GT cro-mo forks
[Closed] old GT cro-mo forks
[#4314327]
What do You think about older GT cro-mo forks? They weight abot 990gr, about 180gr heavier than the alu Cannondale Pepperoni I have, but maybe it's worth to swap, because of comfort...
Posted : 31/08/2012 11:57 am
Any other solutions? Other light weight steel forks?
Posted : 31/08/2012 2:53 pm
Depends on the frame the axle to crown length will be quite short on older forks. Carbon would be the other option for light weight bump absorption.
Posted : 31/08/2012 2:54 pm
Kona P2's?
Posted : 31/08/2012 2:58 pm
We are talkin' about a Marin Team Issue frame from the '90s. So I think the A-C length should be about 390-415mm.
Are the Kona P2 forks lighter than GT? I don't think so...
Posted : 31/08/2012 3:00 pm
I think Marin came with Rockstar forks which are reputedly quite a good fork. Others you could consider are Spinners, a triple butted set should be fairly light and ride nice or for a little bit more money a set of Ritchey forks would be really nice. Of course P2's, Spesh Direct drives and GT forks are all fine but personally I don't like mixing and matching from other manufacturers for some reason 😕
Posted : 31/08/2012 3:07 pm
I think the triple butted versions are....
The frame has 1 1/8" A-headset, so I need forks for that.
Posted : 31/08/2012 3:09 pm
If the GT forks are the ones I'm thinking about (came on loads of mid-90s GTs) then they won't be comfy. Fair beefy non-tapered legs meant they were really harsh.
How much do you want to spend? Shorter Salsa Cromotos would be a good option? Think the shorter versions (420mm?) come with canti mounts too. Lovely forks... got some of the longer ones on my Curtis S1.
Posted : 31/08/2012 3:34 pm
triple butted ones are nice forks. cheaper varieties are MUCH harsher.
I downgraded (long story) and you really can tell the difference.
Posted : 31/08/2012 3:40 pm
The forks are a black GT, with eyelets the two sides of axle. (for fender and maybe rack... ) But I don't know much more about that forks and don't have any pics.
Posted : 31/08/2012 3:53 pm
I have just found some pics of GT forks...
[url= https://plus.google.com/u/0/photos/101548000249852054009/albums/5782910045862976689?hl=hu ]GT forks pics[/url]
What do You think? Are they worth to upgrade?
Posted : 31/08/2012 7:45 pm
