A mate's got an old Orange Gringo - I think 2000 or 2001 model.
It's got Manitou (Magnum?) forks on it, which are a coil / elastomer unit. So far as I can see, the elastomer acts as a bump stop and perhaps provides a bit of damping.
It's also got what look like post mount fixings for a brake caliper. Now - are they post mount? Were things standardised back then? Or can I expect some random fixing and a selection of adaptors to make a caliper fit?
Manitou have always been PM I think.
Personally I'd be wary of disks on a fork of that vintage - they tend to be a bit 'twangy' with disks.
Yup they were standardised (and possibly sh1te!)
EDIT: unless they are structurally damaged I can't see why not to use (small) discs on them.
They're PM but Manitou's were really crap around then
Some early ones had a slightly closer spacing (69mm?) As others have said they'll be a bit rubbish, you'll get better forks for £20 from the classifieds
MrsDezb's bike has old Manitous and the mount spacing is definitely NOT standard post mount. I guess it's what nickjb says - 69mm.
Hang on I'll find a pic.
Righto, looks like I'm after a cheap set of forks too!
The V-posts are missing, so it seems a bit daft to go buying them, then some v-brakes. Will end up costing almost as much as a second hand set of discs.
You might get a few quid on 'retrobike'
Mostly. X-verts and a couple of their DH forks were pretty good though, although they did need as much love as modern Fox units.
