Oil my brake levers...
[Closed] Oil my brake levers?
[#903600]
One of my brake levers has got squeaky and sticky (despite not really seeing much mud - I've only had it since March). So when I pull it, there's resistance then it suddenly moves... Which makes my braking very on/off.
The obvious solution would be to spray some oil around, but would it do any harm?
Brakes are last year's Shimano XT hyraulics.
Any wisdom appreciated...
Posted : 28/09/2009 12:45 pm
Be very careful about spraying lubes around Hydraulics, you'll probably be fine with yours but DOT based systems can definitely have their seals damaged by certain types of lube.
Posted : 28/09/2009 7:15 pm
Perhaps try a silicon spray which is inert and shouldn't affect any seals or try some of the actual brake fluid on the pivots?
Posted : 28/09/2009 7:32 pm
