As above, I'm trying to find the above shock for my Enduro, has anyone fitted this coil to their medium spech and what it the exact size ?
I ring up Ohlins dealers and they don't know ? 😐
Give TFTuned a call, there are TTX shocks that are specific to the Enduros - TF will know which model you need.
I’ve recently just got the ttx shock with Specialized fitment for my levo. (Based on stumpy /camber and maybe 29er travel). Wasn’t cheap, but Plush suspension have them and do a great set up etc to.
Cheers guys 😉
Hello guys, I see that the STX 22 Air is listed as being available for Levo mounting and the size there is 196 x 47. Though personally I would be more interested in the TTX coil version as an upgrade.
Well the TTX arrived from Tftuned and doesn't fit my frame 😥 ... the shock body is rubbing up against the top frame, Specailized is a nightmare !
I’m sure tf will sort it out or email Spesh and ask which one you need as they used to sell the shocks through Specialized dealers as an upgrade
I've rang up Spesh UK and Tftuned have tried their very best but its the actual frame sizing which is causing the problems, not enough room for the piggyback to sit in the top mount of the frame.
Tftuned are now sending me a different Ohlins to see id this variant will fit, hope it does as the standard shock is bollox
