i have a set of mavic Ksyrium wheels and i canot get the rear cassette for fit. Basically no matter when i tighten to the suggested torque (40nm)the cassette still has play in it and i can move rings 1 - 7 - there is a gap of around 2mm. i have fitted cassettes for years and none of the 3 roads sets i have fit which leaves me to think it must be the freebody. any suggestions??
do you need a spacer behind the cassette?
Is it a 9 or 10 speed casette? From memory, if it's a Shimano 9 speed you need a spacer behind 1st that should come with the wheels. Prob somthing like that.
nope 10 speed but definatly in need of a spacer.... anyone got one knocking about??
Yes two spacers the mavic (roughly 2mm) spacer and the thin 10 speed spacer if using a 10 speed cassette.
My advice is based on Shimano - **** knows for Campag 😆
if anyone has some of these spacer knocking about, i'd appreciate it if you could pop on in the post to me.... need to sort this for a hilly sportive coming up...
one_sphATyahoo.co.uk
Just use a HTII BB spacer.
thanks Druidh.....
