Nukeproof Generator...
[Closed] Nukeproof Generator - 20mm?
[#12387075]
Does anyone know if the nukeproof Generator front hub can be adapted to 20mm?
I thought it could, but I can only find stuff saying 15mm or QR.
Posted : 18/05/2022 6:52 pm
That is both helpful and unhelpful! Thank you!
Posted : 18/05/2022 11:13 pm
Maybe not directly but have a look at the bearings, either they have 20mm inner diameter or could be swapped for ones that do, I essentially did the same operation to convert my Hope XC to 15mm (with an additional machined spacer and end caps). Always worth checking. If you can get the correct size bearings speak to Kayla1, she made up the rest of my conversion kit.
Posted : 19/05/2022 5:55 am
my nukeproof generator front hub is 20mm and i`ve the 15mm adaptors in a box somewhere.
they may have changed the design now though as its a good few years old.
Posted : 19/05/2022 12:03 pm
Yes, my old Mega had 20mm axel Marzocchi 55's on it.
Posted : 19/05/2022 12:05 pm
